1992 W250 360 tbi GAS under 60,000 miles
Unfortunately, I have to let my w250 go. Its got the nv4500 5 speed manual trans backed by a np 241-D t-case. First off, this truck is a 92. It is not a show truck. It is, however, in excellent shape for its age. I bought the truck about four years ago from my boss. It was originally a guard truck for Leavenworth prison systems. The truck wasn't in bad shape, but needed floor pans and minor body work. We took care of all that and a professional painter shot it with single stage epoxy paint. The interior is not original. It has two bucket seats from a grand prix, and a chevy center console. Rubber floor mat from a 70 something dodge truck. Carpet from the mat to the back of the cab. It finished out really well. The headliner sags a bit, but no holes. One or two pieces of interior trim are cracked in one place, but all there. I drive this truck 160 miles a week for work and have taken it to Kansas and back twice and had no issues. Bought the truck with 30,000 miles and put almost 30,000 more on it. I have kept up on all maintenance and replaced anything that needed it. Also changed all the gear oils when I bought it.
-Fuel pressure regulator
-Map sensor
-Coolant temp sensor/sender
-TPS
-MAP sensor
-this is in addition to plugs/wires, cap/rotor, etc.
Now a bit about the outside.
-Ramsey winch bumper on the front coated in bed liner
-new grille/inserts
-good paint
-NEW TIRES <5,000 miles on them!
-ProComp Rims
-custom designed/built 1/4 plate steel rear bumper covered in bed liner.
-Very, very minimal surface rust above wheel well
-Small spot of rust on passenger side rocker (It looks like a possible thumb print before painting... Very easy fix, I have extra paint.
- no major dents
-the only rough part of the outside is the tailgate. Truck didnt have a tailgate when purchased, so I got one from jc whittney and it needs to be replaced.
No mechanical issues, a good running truck. I would take this truck anywhere and not worry about it. I think the valve covers leak a bit of oil, but I have new gaskets and may put them on in the near future. I am located 20 mins east of St. Louis in Edwardsville, Illinois. I can also meet you within a reasonable distance. I'm asking $5000, but will work with members of this site within reason. Probably wont go much under $4500 simply because it has 1200 in new tires alone. Feel free to PM me and I'll give you my number and can also send more pictures. I may trade for a 4x4, just let me know what you got.
Thanks,
Brian
-Map sensor
-TPS
-MAP sensor
-new grille/inserts
-good paint
-ProComp Rims
- no major dents
Thanks,
Brian
