Notices
2004 Dodge Neon SRT4 Mopar Stage 3
Old Apr 22, 2013 | 04:27 PM
mikehouston's Avatar
mikehouston
Default 2004 Dodge Neon SRT4 Mopar Stage 3
Selling my SRT4. It has 128k miles on it. Will go up as it is my DD. $9500 OBO.
Located in Charlotte, NC
Mod List: Big Wheel Stage 3 (20G Compressor Wheel, ported Compressor Housing with TD05 Exhaust Wheel) done by Bob / MAP.
Ported intake manifold.
Hondata Plastic Intake manifold Gasket. Link here: http://www.modernperformance.com/pro...e_throttlebody
LFS 60mm Throttle Body.
3" Downpipe
3" Straight pipe exhaust.
3 bar MAP / TIP.
Stage 3 PCM.
Stage 2/3 Injectors (682cc)
Forward Motion Stage 3 WGA.
Mopar Turbo Toys.
Greedy Turbo Timer.
UEGO Wideband.
AGP Fuel Return Line.
Brand New DEPO Projector head lights.
BC BR Type Coilovers.
Mopar Strut Tower Bars.
Eibach Sway bars.
Kaminari Carbon fiber hood.
Walbro 255 Fuel Pump
FWD Defeated Fuel Pressure Regulator.
Injen Short Ram Intake.
Maddog Short Throw Shifter
Other things that are not installed but will be included with the sale
extra Mopar Stage 3 Fuel Rail with rasing rate regulator on the rail.
stock Mopar Stage 3 WGA
Extra set of Head lights: MPX verison 1 Halo Projector lights.
Stainless Brake Lines
Stainless Clutch line
I am sure I am missing stuff. Full boost is 25 psi at about 3300 rpm. Only Full Syn Oil Ran.
Mopar Stage 3 Turbo is a Factory upgrade from Mopar for the Car. It used a larger Turbo (TD05) , bigger WGA and Larger Exhaust Manifold and O2 Housing. As well as larger injectors. With the Mopar Stage 3 PCM there is NO Tuning Needed!!! The Turbo that is on the car has been rebuilt and has a larger compressor wheel than a stock stage 3 turbo. The Turbo Toys was also an option through Mopar. This provides a boost controller in cabin, Intercooler Sprayer, and High Octane Mode Switch for use with 100+ Octane. Works best with 110 of higher though.
