87 d50 with swapped 5.9 360
1987 Dodge ram50
swapped 91 dodge 5.9L 360
runs good may need some tuning
minor rust spots
custome front end/ radiator support, solid engine and trans mounts
Engine:
1991 5.9L 360 pre magnum
rering kit with new bearings and seals/gaskets
all new exhaust valves
comp cams 268H flat tappet cam
comp cams 1.6 adjustable rocker arms
edelbrock performer intake manifold
holley 600cfm 4 barrel carb
mopar performance ignition system (chrome Box)
mopar performance valve covers and air cleaner
high volume oil pump
chrome alternator 95amp
Custom 1 5/8 headers to 2 1/2 side exhaust with glass packs no cats
adjustable electronic cooling fans
Transmission:
pro built 727
New clutches and seals
kevler bands
deep chrome oil pan
trans brake with manual valvebody
B+m mega truck shifter
Body:
3 inch body lift
some minor rust spots ( nothing through the body pannels)
few minor cear coat peeling
Rear end:
stock rear with LSD and 3.91 gears
custome built drive shaft
ps also have a 8 3/4 rear end 489 casting from a 69 charger for additional $200
http://cgi.ebay.com/ebaymotors/87-Do...QQcmdZViewItem
