Notices
2015+ RAM 1500 Edge Pulsar ECM
Old May 19, 2019 | 08:59 PM
m_durham_226's Avatar
m_durham_226
Default 2015+ RAM 1500 Edge Pulsar ECM
$380 + shipping and will not ship internationally
Price is non negotiable. This is $500 brand new and this one was used for only 2 months.
If you know anything about the 2015 RAMs then you know it’s hard to tune these trucks because of Dodge locking the ECMs and only the dealer can unlock. This particular tuner hooks up to your stock ECM and bypasses everything. Easy to swap out if needed to go to dealership for some work. Three 10mm bolts and two wiring harnesses. They would never know it was on there.
This particular unit was used in my 2015 RAM 1500 for total of two months. Added almost 4 mpgs!!!!!.
Below are the capabilities of the unit itself and a video explaining for about it.
•User-adjustable power levels via cruise control buttons
•Adjustable power levels on-the-fly
•Improves economy, towing capabilities, and performance
•8 performance levels – stock, economy, tow, performance
•Power level displayed on OEM dash
•Adds up to 15 HP and 15 ft-lbs TQ
•Advanced ignition timing (spark)
•User-selectable level with MDS on/off
•Adjusts accelerator pedal response to drastically enhance the driving experience
•Adjust tire size: 20" - 59"
•Adjust gear ratio: 2.00 - 5.99
•Pair with Edge CS2 or CTS2 Insight
The Edge Pulsar Programmer is an incredible new tuner featuring the easiest installation and control over vehicle power levels. The Pulsar Programmer is an in-line computer that connects directly to the vehicle PCM with no additional wiring hardness. Unlike other tuners there is no modification necessary to the PCM for this installation.
The most unique feature of the Pulsar tuner is the ability to control 8 different performance levels using the vehicles cruise control "+" and "-" buttons on the steering wheel. These performance levels can be switched on the fly adding up to an extra 15HP and 15TQ from your Hemi engine.
The Pulsar is now available in a kit with the Edge CS2 or CTS2 Insight monitor. When they are paired together you have the ability to switch power levels on the monitor, monitor key vehicle parameters, and adjust tire size and gear ratio all controlled through the steering wheel.
