98 Ram SS/T
Red with silver strips
4.56 gears
Kumho 285/60/17 low miles
lowered 2" in the rear
DJM upper control arms
roll pan
Plastic bedliner
Extang tonneau cover
Flexalite dual 15" elec fans
ASP underdrive crank pulley
MSD ignition and coil w/ 8mm wires
M-1 2bbl
F&B 55X52mm throttle body
Comp Cams stainless 1.6 roller rockers w/ heat treated push rods
Mopar double roller timing chain
Comp cams/KRC 218 cam
Stock heads with new valve job, guides, springs and seals.
NX wet kit w/ bottle heater, low fuel cut off switch, autometer A/F guage
Mopar PCM and stock pcm
Pace Setter Headers w/ custom 2.5" Y pipe and single 3.5" exhaust
15X8 rims with Hoosier quick time pro's
APS 2800 stall torque converter
Hitch w/ brake controller
I might be missing a couple of things but that's all I can think of.
This truck has 115K but all the motor work was done at 100K. This truck runs great but with a new addition to the family I'm going to need something with more room. The only thing I had left to do was 408 bottom end and porting the heads but that'll have to be up to you. I don't remember the exact numbers but they only built like 2600 SS/Ts in 98.
The only problems are the exhaust is dumped at the axle so it's loud (sounds like a big block), dash is cracked, the paint on the plastic grill is chipped and the a/c evap needs to be replaced. These are just minor things but still something you should know.
I'm asking $9000, If you would like some more pics just pm me your email address.
Michael
http://www.putfile.com/blown03gt
4.56 gears
roll pan
Plastic bedliner
M-1 2bbl
Michael
