Notices
412 cubic inch / 500 horsepower- Dakota
Old Mar 11, 2006 | 03:51 PM
hardtohitme7's Avatar
hardtohitme7
Default 412 cubic inch / 500 horsepower- Dakota
96 dakota
412 cubic inch / 500 horsepower Mopar Stroker Motor By Mike Yank. Balanced And Blue Printed ,10.5 to 1 Compression, Crank Shaft By Ohio, Pistons By J&E, Rods By Eagle, Rings By Speed Pro, Camshaft By Comp Cams, Intake .532, Exhaust .535, Duration, 282 / 285, Lifters By Engine Pro, Heads By Mopar Performance / Aluminum-Bare Castings, Ported and Polished, Oil Pump by Melling, Flow Kooler High Flow Water Pump, Milodon 6 Quart Oil Pan, Custom Made 5 Rail Radiator, Derale “Twin Tornado” Dual 13 Inch Electric Fans.
Dr Evil, “Maximum Evil” 518 High Performance Transmission W/ Overdrive.
Basic Information Available At www.dreviltransmissions.com.
B&M Shifter, GS Motorsports Big Tube Headers, 410 Mopar Posi Rear End with Yukon Gears, MSD Ignition, MSD Remote Timing Control, Hughes Torque Converter-3000 Stall,
Demon “Speed Demon” 750 Dual Feed Carb, K&N Filter, Competition Engineering “Slide-A-Link” Traction System, Top Gun 100 HP Nitrous System, Borla “Turbo” Mufflers, Catco High Flow Cats, True Custom Dual Exhaust, American Racing Wheels With Nitto Extreme ZR Tires 255/45/17, PST Upgraded Front Slotted Rotors And High Performance Brake Pads, new shocks front Monroe Sensortraks, Rear, Rancho 5000s.
Motor and Trans have about 4000 miles on them.
Everything works including the air conditioning!!!
Comes with two Nitrous tanks and two “Weld Racing”, 10X15 inch racing wheels for slicks.
On just the motor runs low 12's.
With the nitrous, low 11s on a 100 shot.
The motor was built to hold about a 200 or more shot which put in the low 10s
pics---------http://www.81x.com/nightmoves/tyedye
Street/Strip/Show Winner
$13,500.00 Or Best Offer
Old Mar 22, 2006 | 02:38 AM
hardtohitme7
Default RE: 412 cubic inch / 500 horsepower- Dakota
no one interested in a bad *** truck that you can out run corvettes and LSX's in
