Notices
SSBC electric vacuum pump and Comp Cam Vacuum canister
Old Aug 3, 2006 | 02:09 AM
DieselDemon's Avatar
DieselDemon
Default SSBC electric vacuum pump and Comp Cam Vacuum canister
For sale. Brand new Stainless Steel Brake Corp electric vacuum pump kit p/n 28146. Also included with sale is a Comp Cam black vacuum canister p/n 5200. I tried to install in my pickup truck but there was not enough room, and switched to a hydroboost system. Comp canister has barbed fittings, check valve, and mounting studs with nuts. SSBC electric pump has relay, vacuum switch, rubbber isolation mounts, and wire. I have instructions also, somewhere.
Used when proper amount of vacuum is not being generated. Pump comes on at 18 inches of vacuum and shuts off at 22. This is the ideal setup for supercharged motors that do not create enough vacuum, or in addition to your current vacuum setup. Used extensively in drag racing applications. Will make everyday brake applications much easier with not fade or stiff pedal due to loss of vacuum. Pump comes on and off automatically. The Comp canister give you additional brake applications due to the extra large vacuum storage tank.
First $225.00 takes it. Shipping and insurance are on me. I accept payal, or you can mail cash or a postal mo. Thanks.
Email DieselDemon@stny.rr.com
