Notices
Regular cab sub box and sub
Old Aug 29, 2006 | 02:09 AM
Andy4.7's Avatar
Andy4.7
Default Regular cab sub box and sub
It worked great in my 02 Ram RC, but of course you could use it in whatever you want.
$125 SHIPPED for box and sub (48 states only)
Q-Logic Box
Q-Logic enclosures take the guesswork out of box-building, so you can enjoy great bass without the time-consuming process of constructing your own enclosure. The QLT-1.2512SE accommodates one 12" subwoofer in a sturdy housing made entirely of non-resonant medium-density fiberboard. This box features reliable locking-joint construction, and is impeccably upholstered with durable gray carpet.
Since subwoofers' basket design and bolt patterns vary by brand, Q-Logic's ingenious QxE seal ring allows you to customize the box opening for virtually every woofer available. Plus, a cool-looking, one-piece grille works even with woofers that have large roll surrounds, so you get solid protection and sharp looks.
The box comes with a round, pressure-fit grille, gold-plated binding posts, and speaker leads with attached quick-slides for easy connection to your woofer.
This box is designed to fit behind the seat in your pickup.
Key Specifications:
for one 12" subwoofer 1.25 cubic feet internal volume dimensions:
width: 26-7/8"
height: 16-5/16"
bottom depth: 9-1/4"
top depth: 6-1/2"
Rockford Fosgate 12" sub
Rockford Fosgate RFZ3412
Rockford Fosgate subwoofers are built for the same people that use their Punch® amplifiers: fanatics. Primarily designed for small sealed or ported enclosures, The Punch Z subwoofer delivers a wallop of bass without needing a lot of power. The new poly cone features a redesigned dust cap with the embossed RF logo. The Punch has features typically reserved for more expensive subwoofers including a XTended pole piece and bumped back plate for extended bass response and aluminum voice coil for optimum heat transfer.
Features
1.5" 4 Layer Voice Coil
Coil on Aluminum Former
Flat Spider
Polypropelyene Cone
Hyper XTtended Pole Piece
LXcursion Basket
Rubber Magnet Boot
Subwoofer Specifications
Rec. Sealed Box Dims: 1.00 - 1.75 cu.ft.
Rec. Ported Box Dims: 1.75 - 4.00 cu.ft.
Free Air Usage: not recommended
Sensitivity: 90 dB
Frequency Response: 20-200 Hz
Recommended RMS Power: 150W
Peak Power Handling: 400W
Impedance: 4 ohms subwoofer wiring option
Old Sep 9, 2006 | 12:07 AM
Andy4.7's Avatar
Andy4.7
Default RE: Regular cab sub box and sub
bump
Old Nov 7, 2006 | 06:40 AM
Andy4.7's Avatar
Andy4.7
bump
Old Nov 15, 2006 | 03:28 AM
Andy4.7's Avatar
Andy4.7
bump
Old Nov 28, 2006 | 03:03 AM
hotrod90019's Avatar
hotrod90019
Would you sell just the box? PM me!
Old Nov 28, 2006 | 01:27 PM
User's Avatar
User
DUDE OMG.. where did you get that box.. ive been trying to find one of the old q-logic boxes like that.. with the ring in the front. Ill buy that box from you if you dont need it.
Old Nov 28, 2006 | 04:51 PM
Andy4.7's Avatar
Andy4.7
I got the boxes from crutchfield. And I just it on ebay.
