Notices
2nd gen ram stuff
Old Sep 6, 2006 | 01:32 PM
GOD RAM IT's Avatar
GOD RAM IT
Default 2nd gen ram stuff
ok Im cleaning out my garage, time to get rid of some stuff
trail master long arms - $100 shipped
35x14x15 bias ply ground hawgs on 15x10 rock crawler simulocks (5 on 5.5 lugs with 3.75" BS)
$650 pick up only
if wanted seperate $450 for the tires and $250 for the rims.
if someone buys my rims and tires for $650, I will give them all of the below parts or what ever they want out of them. (long arms not included)
now for the other stuff. Most of it is best offer
everything below that isnt sold, can be had for $100, no shipping. I can meet a short distance
skyjacker steering stabilizer
stock shocks and steering stabilizer
4 never used lower control arm bushing sleeves *sold*
shock boot
3 steering shafts (with 3" body lift spacers)
brand new never used rear drum brake pads from NAPA
idler pulley (I removed it because I thought the bearing was bad, it turned out to be my water pump bearing)
stock bumper brackets (f and R)
tow hitch (I cut the welds to turn it upside down to work with a body lift but I never wound up doing it.)
brand new tranny filter with rubber gasket
stock steering
used 1 ton chevy tie rod ends (all of them) *sold*
stock rear mud flaps
stock springs
stock ring and pinions and fron carrier
2 spare front wheel hub bearings *sold*
used Accel 8mm spark plug wires
sway bar
rear plastic license plate holder.
stock skid plate for the transfer case
exhaust manifolds (no leaks)
2 pieces of the stock air box
Old Sep 8, 2006 | 01:54 PM
sephirothq's Avatar
sephirothq
Default RE: 2nd gen ram stuff
I could really use some of the stuff you have there.
Like the rear brake pads.
I need a stock steering setup for a 1995 ram. my tie rod ends are bad.
the front sway bar. Mine is bent.
the front hubs would be nice to have as well.
let me know what you want for the stuff, and where you are located.
Dave
Old Sep 8, 2006 | 02:42 PM
GOD RAM IT's Avatar
GOD RAM IT
Im located in central New York.
PM me an offer and we'll go from there
thanks
Bill
Old Sep 12, 2006 | 04:11 PM
GOD RAM IT's Avatar
GOD RAM IT
All of the parts besides the tires and long arms for $100 pick up only ( I can meet somewhere if necessary).
