2006 wire codes
Constant 12V - Gray/Red
Accessory - Can-Bus (None behind the radio, must grab an alternate location for ignition)
Left Front Speaker (+) - Dark Green/Yellow
Left Front Speaker (-) - Dark Green/Light Blue
Right Front Speaker (+) - Gray/Yellow
Right Front Speaker (-) - Gray/Light Blue
Left Rear Speaker (+) - Gray/Light Green
Left Rear Speaker (-) - Gray/Dark Green
Right Rear Speaker (+) - Dark Green/Light Green
Right Rear Speaker (-) - Dark Green/Gray
ORIGINAL: jake99buell
So i need another place to for my remote wire and there is no ground wire? If i cant put my remote wire behind the radio where can i put it?
Yes, you have to use another wire that gets 12v+ only when the key is turned on for the remote wire.
