Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Need Help!!!
Old Sep 6, 2004 | 03:24 PM
MicRam's Avatar
MicRam
Default Need Help!!!
Hey guys, i have a 2002 quad cab ram, well i have my box/subs and amp that i pulled from my old explorer, and i was wondering about a few things. #1. I have a hard tonneau cover, so what is the best way to run the wires from the bed to the front? #2. How do i pull the stock headunit out so i can configure the wires. #3. Can i hook up everything to the stock headunit? Any pictures on how to would help alot. thanks.
Old Oct 14, 2004 | 04:20 AM
millenniumdna's Avatar
millenniumdna
Default RE: Need Help!!!
#1 anything thats neat and clean. Some people drill small holes. #2 This could be different based on your model. I would suggest taking it in and having someone look at it and give you options. #3 yes you can, but it will not sound as good as if you installed an aftermarket head unit that has built in "PREOUTS" to hook up to the stock head unit you will need to get a RF Modulator from your local radio shack or what have you. This however will reduce sound quailty.
