Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Amp mounting method behind QC rear seat
Old Apr 17, 2007 | 07:37 PM
McGillicutty's Avatar
McGillicutty
Default Amp mounting method behind QC rear seat
Say, how did you fellas mount your amps on the rear wall of the quad cab? I was thinking about mounting my amps on an 1/8" thick sheet of aluminum and then either epoxying or velcroing the aluminum to the rear cab wall. I mean, it's not like you can screw them up there unless you don't mind holes in your cab.
Old Apr 17, 2007 | 08:13 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: Amp mounting method behind QC rear seat
Ive screwed them right to the wall, they stick out the back a hair, but noone will see it, and a little filler fills em right back in if you remove it.
Old Apr 18, 2007 | 02:18 AM
HighDuke1911's Avatar
HighDuke1911
why not just put em under your front passenger seat?
