Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
wiring
Old May 17, 2007 | 11:15 PM
kenc07's Avatar
kenc07
Default wiring
Hey, can anyone help I need wiring diagram for 2005 sebring stereo with standard system.
Thanks Ken
Old May 17, 2007 | 11:58 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: wiring
I'm showing standard wiring
Constant 12V+ Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Antenna Left Rear
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Old May 18, 2007 | 02:30 AM
kenc07's Avatar
kenc07
Default RE: wiring
The wire colors don't match up.
Thanks Ken
I have;
pink
green/brown
red/white
orange/gray
brown/yellow
brown/yellow
purple
brown/blue
blue/red
blue/orange
blue/white
brown/ornge
green
black
Old May 18, 2007 | 02:47 AM
habeba86's Avatar
habeba86
Default RE: wiring
Is it a coupe, convertible, sedan??
Old May 18, 2007 | 11:13 AM
kenc07's Avatar
kenc07
Default RE: wiring
It is a sedan
Ken
Old May 18, 2007 | 12:55 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: wiring
Constant 12V+ - Pink
Ground - Black
Switched 12V+ - Red/White
Dimmer - Orange/Brown
Power Antenna - Dark Green/Red
Left Front (+) - Dark Green
Left Front (-) - Brown/Red
Right Front (+) - Purple
Right Front (-) - Blue/Red
Left Rear (+) - Brown/Yellow
Left Rear (-) - Brown/Light Blue
Right Rear (+) - Dark Blue/White
Right Rear (-) - Dark Blue/Orange
Hope this helps
Old May 19, 2007 | 01:58 AM
habeba86's Avatar
habeba86
Default RE: wiring
rt's info is what I have also.
Old May 19, 2007 | 02:08 AM
kenc07's Avatar
kenc07
Default RE: wiring
Thanks everyone,
that looks right I seem to have an another purple/white wire with power wires that is not pointed out will test out tomorrow.
Ken
Old Aug 11, 2007 | 09:44 AM
paxmaster2000's Avatar
paxmaster2000
Default RE: wiring
i have a 04 dakota with the stock radio . do you happen to have the wiring forthe 10 pin that controls the cd changer .etc?
Old Sep 2, 2007 | 11:06 PM
luvmytrk's Avatar
luvmytrk
Default RE: wiring
RADIO C1 - WHITE 22 WAY
CAV
CIRCUIT
FUNCTION
1
2
X12 20RD/WT
FUSED IGNITION SWITCH OUTPUT (RUN-ACC)
3
E2 18OR/BR
PANEL LAMPS DRIVER
4
5
6
7
X54 20VT (EXCEPT JR27 BASE)
RIGHT FRONT SPEAKER (+)
7
X80 20LB/BK (JR27 BASE)
RIGHT INSTRUMENT PANEL SPEAKER (-)
8
X56 20DB/RD (EXCEPT JR27 BASE)
RIGHT FRONT SPEAKER (-)
8
X82 20LB/VT (JR27 BASE)
RIGHT INSTRUMENT PANEL SPEAKER (+)
9
X55 20BR/RD (EXCEPT JR27 BASE)
LEFT FRONT SPEAKER (-)
9
X87 20LG/VT (JR27 BASE)
LEFT INSTRUMENT PANEL SPEAKER (+)
10
X53 20DG (EXCEPT JR27 BASE)
LEFT FRONT SPEAKER (+)
10
X85 20LG/DG (JR27 BASE)
LEFT INSTRUMENT PANEL SPEAKER (-)
11
Z1 18BK
GROUND
12
M1 20PK
FUSED B(+)
13
X60 20DG/RD (EXCEPT JR27 BASE)
RADIO 12V OUTPUT
14
D25 20VT/YL
PCI BUS (RADIO)
15
16
17
18
X51 20BR/YL
LEFT REAR SPEAKER (+)
19
X57 20BR/LB
LEFT REAR SPEAKER (-)
20
X58 20DB/OR
RIGHT REAR SPEAKER (-)
21
X52 20DB/WT
RIGHT REAR SPEAKER (+)
22
RADIO C2 - BLACK 10 WAY
CAV
CIRCUIT
FUNCTION
1
X40 22GY/WT
AUDIO OUT RIGHT
2
Z4 22BK/OR
GROUND
3
C235 WT/LB
CD GROUND SHIELD
4
D25 22VT/YL
PCI BUS
5
X112 22RD
6
X41 22DG/WT
AUDIO OUT LEFT
7
Z140 22BK/TN
GROUND
8
9
E14 22OR/TN
PANEL LAMPS DIMMER SIGNAL
10
X160 22GY/YL
B(+)
hope this helps it is the factory pin outs for an 05 sebring sedan
