Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
need installation help
Old Jun 20, 2007 | 03:44 PM
salmonman1's Avatar
salmonman1
Default need installation help
Thanks to all that helped me out in regards to the Infinity Speakers, I will be finishing off my system this weekend and need some help. Dodge Ram ext. Cab
I will be installing Infinity Kappa component 6.5 in the front and two 10" MTX subs in the back Under my seat, I was also thinking of installing 4 midranges in my side panel in the back. I have not yet decided what
kind yet but thinking I will stick with the Infinity. I want to run two amps but only have one preamp outputs on my kenwood is this possible.
Old Jun 20, 2007 | 04:10 PM
Captain Pioneer's Avatar
Captain Pioneer
Default RE: need installation help
sure just split the signal or some amps u can jump the rca output from one amp to another... really depends on the amp... I know my Hifonics amp does
Old Jun 20, 2007 | 04:11 PM
salmonman1's Avatar
salmonman1
could I put a crossover in to split the amps?
Old Jun 20, 2007 | 04:18 PM
Captain Pioneer
I dont unles you are cutting out certain freqencies... Besides the amps built in crossover should be sufficient... but if u already have one than i think you can do that... also i believe stinger or JL audio makes a rca splitter and booster set up but both are not cheap... at least the JL one isnt...
Old Jul 12, 2007 | 07:08 PM
swinger525's Avatar
swinger525
Ya the cheapo 'y-spliiters' work fine for getting more channels from your 1pair of outputs. You cant fade, and you will lose a little bit of Signal Quality, but unless you are running serious power, or really pumping the GAINS you will not notice. It will work better than dropping a ton of money on the Booster from JL.
Also, but the time you get that splitter/booster, you might as well have spent the money on a new HU that has the regular 3 pairs of preouts. And Hi-Volt preouts to boot.
