engine noise ?
just installed new h/u and speakers and i got major whine in radio and aux (sat) but cd is almost perfect tried moving grounds and grounding h/u and unt and stuff live that any suggestions?
ORIGINAL: coondog05
If so check & see if the Audio out/Aux is plugged in all the way..
So only when the radio or Sat Radio is on? Hmmm there is an off chance that the radio wire is grounding somewhere or picking up interference from a point in the wire where it is exposed... With the Sat radio... Definitely check your ground as well as how close you are running your signal wires or RCA's to any large power wire. Also go over the line and make sure that there is no cracks or exposures in the wire
