Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Magnum arm rest DVD system
Old Oct 8, 2007 | 02:54 PM
lostandfound's Avatar
lostandfound
Default Magnum arm rest DVD system
Hi guys!
Did anyone experience any problems with the built in DVD systems on Magnums'? I bought an 06' magnum RT with Nav and VES/entertainment. If I insert a DVD I can hear it but the rear display remains blank - I cant get a flicker out of it...Has anyone taken one apart or gave it a good shake to get it back to life?
Old Oct 8, 2007 | 06:10 PM
marionso14's Avatar
marionso14
Default RE: Magnum arm rest DVD system
sounds like there is no power and or signal to the monitor. if you had power but no signal you would see a flicker but thats about it. try to trace the cables from the source unit to the monitor if no kinks, breaks, tears, or burns and its plugged in, the monitor probly went bad. im not familiar with too many factory systems but is there a switch for the rear monitor? sometimes there are switches for safety reasons
