Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
08 Ram 1500 Radio (sub input)
Old Dec 29, 2007 | 01:58 PM
Hemiroid's Avatar
Hemiroid
Default 08 Ram 1500 Radio (sub input)
Does the 7 speaker infinity system have a hook up for a sub woofer?
Old Dec 30, 2007 | 02:37 PM
Hemiroid's Avatar
Hemiroid
Default RE: 08 Ram 1500 Radio (sub input)
anybody?
please, I'd rather not install only to find out i get feedback upon turning off engine
Old Dec 30, 2007 | 09:51 PM
Hemiroid's Avatar
Hemiroid
k amp installed using a converter
Old Dec 30, 2007 | 11:35 PM
habeba86's Avatar
habeba86
The only time you can add a sub directly to a factory system is if it had a sub in the first place...and then you still have to be careful, because most factory subs are higher impedance than aftermarket subs. And if you go putting a 4 ohm sub on and 8 ohm stable amp it will more than likely eventually burn up or go into protect mode alot.
