Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
12" kicker l7 2ohm? wich amp would be the best?
Old Jan 3, 2008 | 06:00 PM
95 Jamin Ram's Avatar
95 Jamin Ram
Default 12" kicker l7 2ohm? wich amp would be the best?
KICKER
# RMS Power Rating:
* 125 watts x 2 chan. @ 4 Ohms
* 250 watts x 2 chan. @ 2 Ohms
* 500 watts x 1 chan. @ 4 Ohms bridged
# Fully adjustable High- and low-pass crossovers with variable slope and crossover frequency
# Fully adjustable EQ single-band parametric equalizer with variable Q (width), variable frequency and variable boost or cut
# Adjustable channel output phase; left and right channels can be linked or independently adjusted
# Left and right channels can be adjusted together or separately
# On-Board Diagnostics tools to troubleshoot installation problems and check amp status
# Four-setting, user-selectable bass compressor to phatten up your sub bass and adjust to compensate for speaker size, speaker location, vehicle size or listening style
# Low Impedance Operation
# Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal) protects amplifier from accidents, out of spec operation, and misinstallation
# MOSFET Power Supply for high power operation
# RCA output jacks to pass the incoming signal to another amplifier or component
# Allows bridged mono load and a stereo load at the same time. (Not available on mono amps)
# Remote Bass Level Control, and control of signal transfer between multiple SX amplifiers
# Amp Strapping lets you put two mono amplifiers together into a single unit with double the power
# Removable aluminum endcaps protect and hide all your wiring to amp for a clean installation. Leave them off if you need a few inches for clearance or if you like the way it looks.
# Dimensions (With Endcaps): 19-1/4" L x 10" W x 2-1/2" H
SOUNDSTREAM AMP
2-Channel Picasso Series Amplifier
Full MOSFET Circuitry
RMS Power Rating:
220 Watts x 2 Channels @ 4 Ohms
380 Watts x 2 Channels @ 2 Ohms
760 Watts x 1 Channel @ 4 Ohms (Bridged)
PWM Circuitry
4 Gauge Power / Ground Connections
Tri-Guard Protection Circuit
IDI (Inetlligent Distress Indicator) Protection LED
Platinum RCA Inputs and Outputs
Bi-Linear Selectable 12dB Crossovers for Inputs and Outputs (Hi / Full / Low)
Variable Subwoofer Equalizer: 0 - 18 dB
Phase Inversion Switch: 0° - 180°
OEM Floating Ground Input
Tri-Mode Operation
Line Outputs
Frequency Response: 10 Hz - 30 kHz
Damping Factor: >200
Variable Input Sensitivity: 0.5 - 4V
Dimensions: 9-1/2" L x 20" W x 2-1/2" H
2007 HIFONICS ZEUS ZXi6006 2/1-CH 600 WATTS AMPLIFIER
Specifications :
# 2 x 150-WattsRMS @ 4-Ohms
# 2 x 300-WattsRMS @ 2-Ohms
# 1 x 600-WattsRMS @ 4-Ohms
# Hifonics New Illuminated Heat-Sink
# Design With Blue LED Light Pumps
# Hifonics Blue Illuminated Logo
# Maxxsonics Illuminated "M" End Panel Logo
# Audio-Pure Ultra-Fiâ„¢ MOSFETS
# Low-Distortion Class A/B Amplifier Circuitry
# With High-Speed MOSFET Output Devices
# Fully Adjustable Accu-Crossâ„¢ Crossovers
# 18dB Variable Bass Equalization
# Dash-Mountable Bass Remote Control Included
# Fixed 24dB Subsonic Filter
# Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
# SPC Simpatico Twin-Coil Design
# HSMD Hifonics Surface Mount Design
# Gold Oversized 4-Gauge Power Connectors
# Power From The Gods Included
and if you have any other amps that are close to 750watts rms at 4 ohm that would be nice. THANKS!
Old Jan 3, 2008 | 07:22 PM
95 Jamin Ram
Default RE: 12" kicker l7 2ohm? wich amp would be the best?
forgotto add Have a 12" kicker L7 2ohm can only wire it to 4ohm and cant return the sub to get 4ohm version witch amp would be better sub is 750watts rms im thinking kicker. But let me hear what you guys have to say
Old Jan 28, 2008 | 04:04 PM
habeba86's Avatar
habeba86
old post..but is it single 2 ohm or dual 2 ohm?
