Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Stock CD/Radio not working after battery changed
Old Mar 7, 2008 | 10:23 PM
RamExpress's Avatar
RamExpress
Default Stock CD/Radio not working after battery changed
OK, I have a 2001 Grand Caravan and the battery died. After I replaced it, the stock stereo doesn't work any more. I know it's getting power since I see the LED's for the Bass/Treble controls flashing. I'm guessing that is some type of security lock or something. I checked the owner's manual and no help there. I did a search on the forum and didn't find anything.
Does anyone know if there's some kind of code to enter to unlock the stereo?
Old Mar 9, 2008 | 10:10 AM
rtkota5point9's Avatar
rtkota5point9
Default RE: Stock CD/Radio not working after battery changed
Umm no, there shouldn't be any security on there. Does it do this when it's running?? Usually flashing lights/display means low voltage.
Old Mar 15, 2008 | 02:15 PM
RamExpress's Avatar
RamExpress
Thanks rtkota5point9, for the reply.
This is a strange one since I've unhooked the battery several times before and never had any issue with the stereo. This time, I changed out the battery after it died and then had the problem with the stereo. The stereo simply doesn't power on, so no display at all except for the bass/treble slider led's are flashing on/off constantly whenever the key is switched to acc or ignition on with engine running or not and regardless of whether the stereo power switch is on or off.
I did a google search and found a couple sites that do sell codes for factory stereos but couldn't find one for this stereo yet. Apparently, this is a fairly common issue for factory stereos and there's some people who are capitalizing on the problem.
As far as the low voltage issue, I may have something like that since I just noticed the engine light on yesterday and will get it checked this weekend. Maybe that's it.
BTW, I like your R/T! What kind of performance and mileage do you get with that fine machine?
