Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
AMP install
Old Sep 21, 2008 | 02:03 PM
cashcrazy's Avatar
cashcrazy
Default AMP install
I need to get some more power to my door speakers and I have never wired an AMP to anything other than a sub. Can I splice into the harness behind the deck and run the speaker wires to the amp? I usually have the speaker wires run directly from the amp, but I would like to keep the watts that the receiver is putting out.
Old Sep 21, 2008 | 02:14 PM
dhvaughan's Avatar
dhvaughan
typically you run low power RCA patch cords from the deck to the amp. there are some amps that will accept higher powered 'speaker level' inputs. look for that feature.
i don't know what would happen if you spliced speaker output to an amp not designed for it.
Old Sep 25, 2008 | 12:18 PM
12 volt's Avatar
12 volt
yup, youll need high level inputs or
jl clean sweep
http://mobile.jlaudio.com/products_c...php?page_id=94
or
rca line converter
http://cgi.ebay.com/CAR-AUDIO-RADIO-...d=p3286.c0.m14
