Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
stereo wire harness
Old Mar 13, 2005 | 02:31 PM
mtvslick's Avatar
mtvslick
Default stereo wire harness
I am tring to install an Alpine stock DVD nav system in my 300C its the nav system from the 2005 Magnum the large one and the harness wires r differant so does anyone know were I can get the wire diagram of the magnum and the 300C for the stereo plugs? so I can hard wire it in.
thanks!
Mark,
Old Mar 14, 2005 | 01:00 AM
356MAGNUM's Avatar
356MAGNUM
Default RE: stereo wire harness
I used an 04 Durango wiring harness for my SXT with the base 4 speaker system. Im not sure if your 300C has the 6 speaker system. And not sure if the Durango is avail with 6 speakers. If it is then you should be able to use the 6 speaker Durango wiring adapter also.
