Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Mygig RER to JL amps
Old May 21, 2009 | 11:25 PM
alsrt4's Avatar
alsrt4
Default Mygig RER to JL amps
I am trying to install two JL Audio amps, Kappa 6x9s, & a JL Stealth sub, but installer tells me RER will not connect to the high level amp inputs -- that I need to use an eq like the JL cleansweep. I am skeptical. Can the RER send high level output to the amps from the speaker outs? If so, which wires are the speaker outs (RF,LF,RR,LR + & -)??
Old May 22, 2009 | 09:52 AM
drober30's Avatar
drober30
Do you have the upgraded Alpine "Premium" sound?
Old May 23, 2009 | 11:48 AM
audioaddict's Avatar
audioaddict
Unless you're building a competition-minded audio system (and from the equipment you've listed, I'd guess it's just upgrading equipment for good sound), an eq is overkill and a complete waste of money. Use an Adjustable Line-Output Converter off the rear speaker leads, it uses the high-level audio signal, drops it down and converts to RCA signal wires, which will then plug directly into your amplifier.
Old May 23, 2009 | 09:19 PM
alsrt4's Avatar
alsrt4
Thanks. How do I locate the speaker outs on the harness?
Old May 26, 2009 | 10:50 PM
audioaddict
give me a year, make and model and I'll see what wiring info I can pull up
Old Jun 10, 2009 | 11:39 AM
JRam08's Avatar
JRam08
Trying to do a similar thing. If you dont mind would you try to pull the wiring spec for me as well?
2009 Dodge Ram Crew Cab SLT, Non-mygig
Old Jun 11, 2009 | 12:01 AM
lross78550's Avatar
lross78550
[quote=JRam08;1698443]Trying to do a similar thing. If you dont mind would you try to pull the wiring spec for me as well?
2009 Dodge Ram Crew Cab SLT, Non-mygig[/quote
Dittto, I need the speaker wiring for a 2009 Dodge Crew Cab but with the Mygig RER Nav system (not sure the head unit makes any difference in the speaker wiring). I have another question. I noticed that the factory base system has 6 speakers 2 rear door, 2 front door and 2 dash. My question is are both the front are rear door speaker outputs Full Range (no crossovers) I plan on unplugging the front dash speakers and i assume that they are crossed over to keep the lows from going to a 3.5" speaker.
If the front and rear door speaker leads are full range then i can wire them to a Line Output Converter and on to an amp. If however they are crossed over then i need to run the front dash speaker leads to a summing device to reaquire full range sound before i go to the line output converters.
I hope all this made sense.
Thanks for any help you can provide on the wiring.
Thanks
Lee
lross78550@yahoo.com
