95-00 dodge radios
I am trying to wire a '95 Dodge radio into a fifth wheel. other trhan the spkr obvious what are the extra wires for? the two in the middle of the back of chassis (Purple & White/purple); Park(white), ILL (orange), ACC (red/white), BAT (pink). How would I wire this? if I have 12v + and -?
tnx
tnx
Hard to say, colors were not universal. It would be easier if you knew what the radio was out of.
You'll have the 8 wires for your 4 speaker channels, if it's an Infinity radio, one of the wires will be an amplifier turn on, dimmer, illumination, memory, accessory, etc.
EDIT:
Easy way to figure everything out and make wiring nice and simple, pick up a reverse harness from Best Buy or Crutchfield. That will give you clearly labeled wires.
EDIT:
tnx
tnx
