Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Alarm Help
Old Apr 10, 2005 | 02:52 PM
88RamVan's Avatar
88RamVan
Default Alarm Help
Im going to install keyless entry and alarm in my 88 RAM VAN.Does anyone know the wiring for the door locks?Also does anyone know which relay setup I need to use?
Any help is very much appreciated.
Thanks in advance.
Old Apr 11, 2005 | 06:59 PM
88RamVan's Avatar
88RamVan
Default RE: Alarm Help
Just incase anyone ever needs it I found the wiring setup.
RAM VAN:
Constant 12 volts RED AND PINK IGNITION SWITCH HARNESS
Ignition 12 volts DARK BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW OR WHITE (-) AT PIN SWITCH
Trunk Pin Switch SAME AS ABOVE REAR DOORS SAME CIRCUIT AS OTHERS
Parking Lamp BLACK/YELLOW (+) AT LIGHT SWITCH
Power Lock ORANGE DRIVER KICK PANEL OR
Power Unlock PINK BEHIND GLOVE BOX
Reversal Rest At Ground Door Locks
Accessories
Window Up D\ L BLU P\ BRN @ MAIN SWITCH
Window Down R/ WHT S/ VIO
Ign Key Warn LIGHT BLUE (-) STEERING COLUMN HARNESS
Trunk Release N/A
OEM Horn BLACK/RED (-) STEERING COLUMN HARNESS
Headlights LIGHT GREEN (+) AT HEADLIGHT SWITCH
OEM Alarm Arm N/A
OEM Alarm Disarm N/A
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach Signal BLACK/GRAY OR BLACK/YELLOW - AT COIL *
Ignition #2 BLACK/RED IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BLACK IGNITION SWITCH HARNESS
Neutral Safety BROWN/YELLOW AT SWITCH
Brake Light WHITE (+) AT SWITCH
Reverse Light VIOLET/BLACK AT SWITCH
Rear Window Defrost
* Some Models Carburated
