Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
adding Navigation
Old Nov 23, 2009 | 01:09 PM
bohrman44's Avatar
bohrman44
Default adding Navigation
If i add the OEM navigation unit, will i have to have the dealership do some kind of "flash" so my truck reads it as a navigation unit..or will the truck do all that by itself?
Old Nov 30, 2009 | 08:47 PM
04redmach1's Avatar
04redmach1
Just the unit itself will work it. I would HIGHLY recommend and aftermarket unit. Eclipse, Alpine, or Kenwood. 3 of the top headunit manufacturers with litle to no issues
Old Dec 4, 2009 | 12:46 AM
josemer09's Avatar
josemer09
hey i was just wondering if a nav unit from a 2008 300c http://www.dodgechryslerjeepaccessor...n-radio/Detail would fit a 2008 dodge ram 1500 i found one for 200 bucks but i want to make sure it could work on my ram first before i buy anything.
Old Dec 11, 2009 | 04:03 PM
bohrman44's Avatar
bohrman44
Any other time i would most definitely go the after market route...i had a nice kenwood set up, but i have the alpine upgrade and i dont want to deal with losing the steering wheel controls and the back up camera function...
Old Feb 3, 2010 | 06:26 AM
rumblebeee's Avatar
rumblebeee
If you find out let me know I also Have a 08 ram witht he basic cdplayer and want the stoc nav. my email is brradlangan@yahoo.com if you find out- if you put any aftermarket radio in your truck and ever have to take your truck in for service they will always blame your aftermarket radio on the problem and if they do that there is not much you can do your screwed-on this truck its a good idea to do stock- i have had so many problems with my 08 dodge ram and every time i took it in the mechanics said its your radio take it out!
Old Feb 3, 2010 | 11:32 AM
zierbox's Avatar
zierbox
Trying to upgrade to a factory navigation unit has a few problems
The nav head unit only works with the factory premium audio system (matching factory amplifier)
The wiring harness is a little different
The nav unit also requires a gps antenna
The blue tooth unit also requires a microphone input
Old May 23, 2010 | 05:13 PM
foremanjonb's Avatar
foremanjonb
That sucks. I had a free Nav coming but I don't have premium sound so I canceled that. If a buy a pioneer double din nav radio, which bezel will I need because the factory nav bezel is way bigger than the pioneer nav radio. Will the installation kit for the pioneer fill up the rest of that hole in the factory nav bezel?
