Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
installing new head unit help!
Old Dec 2, 2009 | 10:03 PM
buckw3's Avatar
buckw3
Default installing new head unit help!
i own an 07 qc with the premium 7 speaker system and i am going to be putting in a boss bv9990 head unit with 7 inch screen. the new unit pushes 85 watts per channel x 4 i'm going to use the radio replacement interface cable to make the install easier but i am concerned with the factory amp not letting the system reach its potential. Is there any way i can bypass the factory amp and just let the speakers run off the head unit. any hekp would be greatly appreciated thank you
Old Dec 22, 2009 | 03:59 AM
SilentRamAD's Avatar
SilentRamAD
Not 100% sure if this is the correct harness but you can try looking up Metra or another brand with 07 factory amp bypass harness
http://www.onlinecarstereo.com/CarAu...s_70-6504.aspx
if you back up a bit on the site and search all the wire harnesses I'm sure you'll come across one that's perfect.
Old Jan 2, 2010 | 02:23 PM
audioaddict's Avatar
audioaddict
A few things to mention as I read over your post.
1.) Boss sucks. You will be much happier spending a little more money now and not replacing the unit later because it doesn't do what you want/need it to do, it breaks, or both.
2.) This unit WILL NOT put out 85 watts per channel. You'll be lucky to see 85 watts if you add all 4 channels together. Boss does the exact same thing you see other junk companies like Sony, Pyle, Duel, etc do; Use inflated max output ratings to con uninformed consumers into buying a sub-standard product. In reality, you'll see roughly 15-18 watts rms out of any given channel.
3.) Your answer as to bypassing the factory amplifier should be based on the facts stated in issue #2. Your factory infinity system will sound better than your boss radio ran direct to your speakers, not to mention that you've got the 7 speaker package and the radio only has 4 outputs.
So in short, use the integration harness and seriously consider a better radio. If you're looking for an in-dash DVD unit without any sort of navigation or blue tooth features, a quality unit will run you at least $500.
Old Jan 4, 2010 | 11:12 PM
kev@leonescomp's Avatar
kev@leonescomp
im going to have to agree with audioaddict. that receiver is trash, a top of the line pioneer only puts out 22w rms. and thats at 749.00 for a flip out. id save up ur pennies and get a better unit.
kev
Old Jan 4, 2010 | 11:25 PM
Ram_It98's Avatar
Ram_It98
8.5 eonon thouch screen its got bluetooth, ipod, and more i can make phone calls from it its freakin awsome great video and sound couldnt ask for any better.i got it from ebay mines not for sale just thought i would tell more peoole about it $300
