Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
???'s installing a dvd player
Old Jan 26, 2010 | 03:09 PM
SirDanglesAlot's Avatar
SirDanglesAlot
Default ???'s installing a dvd player
i want to replace my stock hu with a dvd player do i need to get a dash kit or anything?
Old Jan 26, 2010 | 03:13 PM
SirDanglesAlot
or does anyone have a suggestion on which dvd player to get?
Old Jan 26, 2010 | 03:28 PM
cloud's Avatar
cloud
Go to crutchfield.com and put in your make and model and it will show you what you can get that requires no cut. Probably a jensen, that is what they point me to.
Old Jan 26, 2010 | 03:49 PM
SirDanglesAlot
mr. cloud you are the man....all questions answered straight from crutchfield, thanks!
Old Jan 26, 2010 | 05:11 PM
ramhunter9's Avatar
ramhunter9
^^^^^ its good to see a newbie helpin a newbie
Old Jan 27, 2010 | 07:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
First you have to come with some ideas of what kind you are talking about. Do you want a flip out or a double DIN HU?
Old Jan 28, 2010 | 02:55 PM
SirDanglesAlot
flip out
Old Jan 28, 2010 | 03:00 PM
DodgeThunder's Avatar
DodgeThunder
Just an idea, I think double din looks alot cleaner. If you put in on crutchfield that you have the navigation in your truck itll show you some nice double din h u.. then just buy the navi bezel for the truck off ebay or something and your set.. no cutting..
Old Jan 28, 2010 | 06:15 PM
JMB3384's Avatar
JMB3384
There are 2 different dashes for our Rams. You have the navigation bezel which has square double din hole and the regular radio which has the control ***** that stick out the sides a little bit creating one half circle on each side. You can get a single din size flip out screen with an aftermarket radio kit in the "****" set up. But if you want a double din size radio you will probably need to buy a new factory dash bezel for the navigation, also with a radio kit and a wire harness for plug and play with your factory wiring.
I persoanlly love Alpine. I think they have some of the best quality products. Check out the IVA-W505/P1 or the IVA-W203/P1. The 505 is a flush 7" touch screen and the 203 is flush 6.5" screen meaning it doesn't flip out. You can find these 2 on Ebay cheaper than a $1000. I believe the brain of the system is built in these stereos unlike most of the flip outs if not all the flip outs. What I mean is you have to hide the brain somewhere which is about the size of the actually stereo itself. That means you have to run a couple wires from the head unit to the brain of the system. Here is the alpine link for the Nav stereos I was talking about:
http://www.alpine-usa.com/product/ca...its-head-units
Also if you buy one of these flush mounts you will probably need this factory dash bezel which usually runs about $100 give or take:
http://cgi.ebay.com/ebaymotors/06-07...Q5fAccessories
I hope this helps!
Old Jan 28, 2010 | 10:08 PM
SirDanglesAlot
ya i would have to buy the dash bezel as too i have the half circles for the *****, which is what i've been worried about the whole time.....
