Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Will this amp power 2x 10'' kenwood shallows
Old Apr 26, 2010 | 10:42 PM
Brado34's Avatar
Brado34
Default Will this amp power 2x 10'' kenwood shallows
so i have a friend who has a infinity 1200 watt amp.. so she says.
its running a single 12; sub does this sound correct?
i was wondering if i could test my subs to see if their blown on this amp with out any problems..
im not sure what the rms is on her amp
Old Apr 26, 2010 | 10:47 PM
Brado34's Avatar
Brado34
she just told me it only has a single sub connection thing.
Old Apr 27, 2010 | 01:17 AM
Bigbody's Avatar
Bigbody
if your just looking to test them then it should do the job you can always test them one at a time you can hook them up to just about any amp to test them no matter what the power rating.
Old Apr 27, 2010 | 03:58 AM
98cherryram's Avatar
98cherryram
Most dual sub setups have a single wire running from the amp into the box, from their it splits into the 2 subs, at least that is a standard setup. More high end setups will frequently run the wiring in a more intricate fashion. As well you must work with whether or not you have dual voice coil subs, most people dont know that a dual voice coil sub must be connected twice to each sub. But again, all that can just be run from inside the box with a single set of audio cable from the amp.
