Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
aftermarket radio won't turn off ?
Old Mar 20, 2011 | 12:08 AM
baller95's Avatar
baller95
I have the exact same problem in my 2005 Grand Caravan ! I just installed a new Sony headunit today and it wont turn off no matter what, read my post of this section for more info!
Old Dec 27, 2011 | 09:16 PM
Dent6's Avatar
Dent6
Default Jeep after market radio won't turn off
This happened to me also, after my son and i put in a new battery in his 2007 Grand Cherokee Jeep, I did as Madcrackeroo said and just pluged up the old factery radio and the recycled the door opening and the factory radio shut off then re-pluged up the alpine and all was back to normal. I guess it just resets the computer somehow. Thanks for the help
Originally Posted by MADCRACKER00
I know what the problem is here but I do NOT know how to fix it... other than running a new KEY control wire from the fusebox. BUT the problem is DODGE GAY A$$ security features. NOW COME ON WHO THE H&LL WANTS TO STEAL A FACTORY RADIO? COME ON PEOPLE!!!
I found this out the hard way. installed an Alpine into my Mother-In-Law's dodge 1500 ram and had the same issue. rehooked the orig radio back in
and I navigated to SHUTDOWN radio Security... AHHHHH
then installed the Alpine.. IT WORKED
shuts off with the key etc.. nice
6 months later she has a new battery installed.. the radio DOES IT AGAIN
the security re-enabled. it will NOT shut off with the key
I contacted PAC PARTS and no one has emailed me back
so the solution is.. RUN A NEW WIRE from the fuse box to the RED WIRE of your radio harness. be sure it is a keyed fuse you jump off of
Old Feb 13, 2012 | 04:26 PM
Brandon Anderson's Avatar
Brandon Anderson
Post
I know this thread is a little dated, but just in case someone comes searching for this information...
Most of the CANBUS adapters must be initialized before first use, and after power is lost (battery goes dead, is disconnected, etc).
An excerpt from the instructions for the Axxess unit I used in my truck:
Originally Posted by Axxess manual
INITIALIZE THE XSVI INTERFACE BEFORE TURNING ON RADIO: With all connections made and harnesses connected to the vehicle, turn ignition key to the ON position for thirty seconds, then turn key off.
This procedure MUST be done first thing after power is restored to the vehicle, or your radio will stay powered on even after you turn your vehicle off.
I disconnected my battery to "reset" the truck's computer, then performed this initialization, and everything worked perfectly.
Old Jan 15, 2013 | 10:20 AM
checkster's Avatar
checkster
I cant get my dapter to work. Do we plug in everything including the new headunit and turn the key on to initialize it. or just plug in the canbus adapter and not the new headunit, initialize it for 30 seconds and then plug in the radio? darn im confused and my new radio wont work..........what a buzz kill.
thanks,
tom
Old Jan 17, 2013 | 01:05 PM
Brandon Anderson
Return of the necrothread...LoL
In general, you'll plug everything in and then initialize the unit. It may work without the radio plugged in. I don't know, never tried that. If your radio will not turn ON however, you have a different issue altogether, and I would recommend starting a new thread so we can help you out.
Old Mar 20, 2014 | 10:14 AM
NHRA21's Avatar
NHRA21
Smile Necrothread
Brandon - Thanks for the post! Solved my issue! The only difference is I had to remove the face plate on my radio to stop it from powering up when I connected the battery.
Old Apr 5, 2020 | 12:17 PM
Sandrab7's Avatar
Sandrab7
Alright I know that this is an old forum but I am really struggling with my stereo staying on. I even struggled before getting it installed, on installing it, because it wouldn't turn on at first. I'm not sure what to do, but my 2008 nitro is currently dead. Like I had to manually unlock it. Idk what to do and I'm about done with this vehicle
Old Sep 18, 2024 | 08:46 PM
BobbyDangler's Avatar
BobbyDangler
Default I Feel Like an Idiot
I had the same issue. Installed the radio, tested it, put the dash back together, and then shut the car off and the radio would not turn off. Took it all back apart, checked the wires, all was well. Then, it occurred to me... I was installing feom the passenger seat where the steering wheel wouldn't be in my way. I leaned over, opened the driver's side door, and the radio went off. The radio and other accessories will not turn off until the driver exits the vehicle. I feel like Jim Carey in Liar Liar yelling "I'm kicking my ***! Do you mind?!"
