Pac-Audio steering wheel interface
So I installed an aftermarket radio knowing that I would need to get an interface to be able to use my steering wheel controls with it. I have the interface and am having alot of issues hooking it up. The instructions say hook the white wire of the interface to the red/black wire in the steering column. I hooked it up and it will not program. If there is anyway to get some help that would be great. This is on an 02 Dodge Ram 5.7L QC. It does have the infinity audio system.
Thanks,
Thanks,
Just to let everybody that is trying to do this know, In 2002 Dodge used two different wires for this. A red/black one or a white/gray one. I hooked the interface to the white/gray one and voila, it works now! If anyone is trying to do this same thing let me know, it's a pain but I got it figured out now.
Hi Chris - I am trying to do this right now - install a PAC-Audio steering wheel control. I have a 2000 Dodge Dakota. My problem is that the 2 screws under the steer column are set in so far, I can't get my Torx driver in, and I'm not even sure what size torx it is.
(Why does Dodge make it so hard to take apart ?? !**@*@&*!)
Can you tell me which size Torx you used to remove the 2 screws under the steering column? Because I probably need to go out and buy an very long thin torx driver to reach them.
Thanks for your help...
