You familliar with ohms?
what are the ohms of your subs and how do you have them wired?
bridging a 2 channel amp will never hurt it, as long as you dont go under its rated ohms
wait a sec
You might want to check your connections
The left channel should go to one sub and the right to the other
If he bridged it, your amp is seeing a 1 ohm load, which is no good
