Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Legacy LD34MUT Manual
Old Dec 19, 2011 | 12:12 PM
mibzzer15's Avatar
mibzzer15
Default Legacy LD34MUT Manual
Would anyone have the manual for a Legacy LD34MUT radio?
Heres the item description for it, http://www.legacycaraudio.com/itempa...?model=ld34mut .
I just bought a 1999 Dodge Ram and it has this radio included in it, was wondering about a few specs on the radio so I need the manual. I am also trying to figure out why there is static on all the radio stations. (I am guessing antenna isn't hooked up correctly, so I need the manual for wiring diagrams and whatnot.)
Thank you!
Old Dec 23, 2011 | 09:24 PM
CaliDodgeRam's Avatar
CaliDodgeRam
I'd just try and find a new radio! My 2 Cents
Old Dec 24, 2011 | 11:47 AM
mibzzer15's Avatar
mibzzer15
I was actually able to pull out the radio and look at the antenna wire.....guy that had it before me cut the wire, and hooked up 2 spade connectors, and didn't even solder it or even use shielding on the coax wire. I am going to bring it to a friend later on that can help me replace the whole wire and antenna now.
