Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Subwoofer cutting in and out
Old Apr 18, 2012 | 11:16 PM
txcowboy27's Avatar
txcowboy27
Default Subwoofer cutting in and out
Hey guys I just installed an amp and sub in my truck and it keep cutting in and out randomly.
Here is what I've checked:
-The amp isn't turning off and not going in protect mode
-I replaced the RCA's
-I have checked all the connections
-I checked the fuses
do y'all have any more suggestions?
Here is my Sub and Amp I have
http://www.techronics.com/caraudio_7...Subwoofer.html
http://www.techronics.com/caraudio_1...er-R5001-.html
Old Apr 23, 2012 | 10:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well youre on the right path, pinched RCAs, loose terminal connections, amp grounding/power issues or maybe a bad sub.
Old May 27, 2012 | 01:24 PM
Shawn Selzer's Avatar
Shawn Selzer
Is the amp getting hot, and what ibm load are you running?
Old May 27, 2012 | 02:17 PM
hillbilli's Avatar
hillbilli
I cant get the links to work so i dont know the specs. Got bad internet connections. Make sure your you got your speaker leads right from the amp. 2ohm/4ohm bridged/unbridged and that the sub can run 2ohm if thats how you have it setup. What guage power wire to you have run to the amp, is it fused, where is it fed from? What guage ground and how is it grounded?
Old May 31, 2012 | 05:34 PM
Johnn123's Avatar
Johnn123
Are all your grounds connected? A ground that keeps coming connected and unconnected will do this.
Old Sep 22, 2012 | 10:46 AM
jmerrill's Avatar
jmerrill
Is the amp new? is it possible that you have a channel failing on the amp? an amp that I had use to do this and it was a failing channel due to the amp overheating.
