Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
OEM Amp Wiring Scheme
Old Apr 29, 2012 | 03:39 PM
mayhem100's Avatar
mayhem100
Default OEM Amp Wiring Scheme
Just put a new cheap headunit in my girlfriend's 2001 Stratur RT Coupe. It had a dead factory headunit, zero sound coming from it and it was stuck on AM, CD was dead...so I replaced it. Got he new headunit in there and predictably forgot all about the Infinity amp under the front seat and didn't hook up the remote turn on wire. She lives about an hour away and I'm going to see her in a couple days to finish the thing off...obviously I'll hook up the remote wire, but just in case I wanted to check on other possible fixes.
Since the OEM stereo had no sound I'm wondering if te amp might be dead as well, so I'm hoping for either a link to a convenient bypass plug for it, or a wiring diagram so I cna splice the speaker wires together at the amp and not have to bother running all new wires to the speakers.
I also figure it might be a fuse...but whch one? She doesn't have the manual.
Thanks in advance guys.
Old May 2, 2012 | 05:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Whenever OEM goes dead I always replace it with after market gear. It sounds better, it cheaper than OEM and is easier to troubleshoot
