Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Wiring question
Old Oct 18, 2005 | 05:25 PM
dubquadds's Avatar
dubquadds
Default Wiring question
I am wiring up an amp and need to know where the firewall is located?
Old Oct 18, 2005 | 05:54 PM
Natedogg625's Avatar
Natedogg625
Default RE: Wiring question
The firewall is what seperates the cab from the engine compartment.
Old Oct 18, 2005 | 10:33 PM
356MAGNUM's Avatar
356MAGNUM
ORIGINAL: dubquadds
If you are wiring up an amp, why not go to the battery that is in the rear next to the spare tire?
Old Oct 19, 2005 | 02:21 AM
dubquadds's Avatar
dubquadds
How would you run the wires out of the cab?
Old Oct 20, 2005 | 02:38 PM
supergenius's Avatar
supergenius
there's holes in the firewall, usually where the other wires for your dash go through... or on some cars/trucks you'll find round rubber grommets in the firewall, just put the wire in the hole frome the engine side and start pushing...
Old Oct 23, 2005 | 03:54 PM
356MAGNUM's Avatar
356MAGNUM
ORIGINAL: dubquadds
My mistake when I saw POWER WAGON, the magnum came to mind haha.
