Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Need some sort of Wiring Diagram.
Old Oct 30, 2005 | 01:48 AM
Smokin_Joe's Avatar
Smokin_Joe
Default Need some sort of Wiring Diagram.
I need to identify the speaker wires on the Stock wiring harness of a 99 Dakota.
Color-specific would be great.
Also, if wanting to hook up the turn-on lead for an Amp, which wire would do the job?
Old Oct 30, 2005 | 03:23 PM
356MAGNUM's Avatar
356MAGNUM
Default RE: Need some sort of Wiring Diagram.
1999 Dodge Dakota Stereo Information
Constant 12V+ Red/Blue
Switched 12V+ Red/White
Ground n/a
Illumination Black/Yellow
Dimmer Orange
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Brown/Yellow
Right Front (-) Brown/Light Blue
Rear Speakers 5 1/4" Rear Corners
Left Rear (+) White
Left Rear (-) Dark Blue/Red
Right Rear (+) Brown/White
Right Rear (-) Brown/Orange
1999 Dodge Dakota Security Information
Constant 12V+ Pink/Black Ignition Switch Harness
Starter Blue/Yellow Ignition Switch Harness
Ignition Blue (+) Ignition Switch Harness
Ignition 2 Black/White Ignition Switch Harness
Accessory Black/Orange (+) Ignition Switch Harness (Heat/AC)
Tach Black/Gray Coil
Neutral Safety Wire Yellow/Blue/Yellow 32 Pin Connector Pin 6 right of Engine (PCM)
Brake Switch White/Tan Brake Switch
Trunk Pin n/a Common with Doors
Parking Lights Black/Yellow (+) Light Switch
Head Lamp Light Green (-) 14 Pin Connector Pin 6 at Switch
Factory Disarm Black/Orange (-) 18 Pin Connector Pin 10 Module Passenger's Kick Panel
Door Trigger Yellow (-) Courtesy Light under Dash
Door Lock Orange /W (REV) Driver's Kick Panel Reverse Polarity
Door Unlock Light Green Driver's Kick Panel Reverse Polarity
Driver's Lock Orange/Black Left Side under Dash
Driver's Unlock Pink/Black Left Side under Dash
Passenger Unlock Pink/Purple Left Side under Dash
Horn Wire Black/Red (-) 74 Pin Connector Pin 17 left Kick Panel
Windows Up LF=Light Blue, RF=Brown/White
Windows Down LF=White, RF=Purple/White
Old Oct 30, 2005 | 09:18 PM
Smokin_Joe's Avatar
Smokin_Joe
Is this Infinity System wiring? I seem to recall a Blue/white and a Blue/orange wire in there. what are those?
