Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Which wire do I connect too?
Old Apr 4, 2022 | 11:53 PM
Moparcuda's Avatar
Moparcuda
Unhappy Which wire do I connect too?
I've installed an after market stereo in my 06 SE magnum and i was told to connect to the center wire in the ignition harness but the stereo only works when to car is started or when the key is turned to the on position.
I'd rather have the stereo working in the ACC position when the car isn't running but I can't find out which wire in the car to make this happen.
Any help would be AWESOME!
Thanks
Old Apr 8, 2022 | 06:48 AM
Moparite's Avatar
Moparite
You need to get a wiring diagram for the ignition switch and see witch one you can use. Usually that's how it's supposed to work key on and acc
