Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
bad FM and NO AM SIGNAL AT ALL!
Old Feb 26, 2006 | 09:52 PM
Qbinican's Avatar
Qbinican
Default bad FM and NO AM SIGNAL AT ALL!
Okay people I need help! I just added and new HU on my charger R/T. Am getting weak FM signal and NO AM AT ALL! Yes the anttenna is hooked up to HU. Can it be a sh*****ty anttenna adaptor or is the factory anttenna not strong enough for my SONY HU?
Please help
Old Feb 26, 2006 | 10:31 PM
highline95jl's Avatar
highline95jl
Default RE: bad FM and NO AM SIGNAL AT ALL!
Severl things could be wrong
A) Bad Connection to the anttenna
B) Bad Antenna adapter
C) **** antenna
I would just recheck all your wiring to the hu first before you go crazy and buy a new antenna. Check the connection to the car as well, and the wiring at the antenna itself. Hope this helps you out some.
Old Feb 28, 2006 | 12:01 AM
stantheman's Avatar
stantheman
check your factory antenna connector, if i remember correctly there is a small wire inside. they do have a tendency to get bent when reinstalling. had that happen to a truck from the factory. its either gonna be in the factory connector or your adaptor. would check there first. next i would follow the anttena wire to where it makes another connection, usally in the right kick panel.
Old Feb 28, 2006 | 04:17 PM
Qbinican's Avatar
Qbinican
thanks for the info. When the weather gets warmer over hre NYC I will hopefully get my problem resolved with out having to spend any more money.
Old Feb 28, 2006 | 04:20 PM
Qbinican's Avatar
Qbinican
well I hope its that easy! Am also dealing with some engine noise that I cant completely get rid of. am 95% posotive that the problem is with HU or EQ ground. SO as soon as weather gets warmer over here In NYC I will hope resolve the problem without having to drop any more money!
thanks for the help.
