Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Stereo Replacement ?
Old Apr 7, 2006 | 09:22 PM
dg4icp's Avatar
dg4icp
Default Stereo Replacement ?
Does any one know how to get the stereo out of a 2004 dodge ram 1500 ? I dont see any way of removing its surround. Plus one other question The speakers are all pluged in with special plugs do I have to splace off those clips to put in new speakers and amp or is there another way around cutting apart the trucks wiring ?
Old Apr 9, 2006 | 12:33 AM
whiteram00's Avatar
whiteram00
Default RE: Stereo Replacement ?
wiring harness is what you need no splice needed, an if ur 04 ram is the same as the 00 ram(no to forsure) once the dash is off there should be 1 bolt on the left bottom an top right of the radio an out it comes
