Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
first radio install question
Old Jul 11, 2006 | 04:43 PM
neoncrazy101's Avatar
neoncrazy101
Default first radio install question
Ok... so i'm swapping a Jensen CD 310X from my moms Subaru into my sisters Neon and i'm running into a few questions. i found the wiring adapter that that is needed. and the plate adapter (i think)
http://walmart.scosche-cars.com/prod...oductID=880487
Plate Adapter
http://www.scosche.com/scosche_carau...B&CategoryID=5 or
http://www.scosche.com/scosche_carau...ItemID=CJ1278B or
http://www.scosche.com/scosche_carau...ItemID=CJ1279B
which one do i need?
and with the wiring adapter how do they work? cause from the picture it looks like its just for another Chrysler Radio not the Jensen.
Old Jul 11, 2006 | 05:13 PM
habeba86's Avatar
habeba86
Default RE: first radio install question
Whatever kit they have at wal-mart that says chrysler on it should work. On the back there is a list of all the applications it will work with. The wiring adaptor plugs into the factory wiring harness, then you splice the wires from your jensen radio into the wires on the adaptor.
Old Jul 11, 2006 | 05:42 PM
neoncrazy101
so does that mean that i have to splice the wires that are already in my moms Subaru?
Old Jul 11, 2006 | 05:43 PM
neoncrazy101
Old Jul 11, 2006 | 06:39 PM
dodgedlr's Avatar
dodgedlr
Do not cut any wires on the car!!!
You take your install kit, and splice that to the wires on the new radio. Then just plug and play.
Old Jul 11, 2006 | 06:54 PM
habeba86's Avatar
habeba86
You will need to get the wiring harness that goes into the back of the jensen cd player unhooked from the subaru. Then splice the wires from the wiring adaptor you buy to the wires on the jensen cd player.
Old Jul 11, 2006 | 07:54 PM
neoncrazy101
ok well got the wiring adapter and the face plate. and now i have a question with the wires. in the instuctions (or aka what each wire is) it said that the blue wire is for the antenea. so how do i connect that wire to the antenea since the antenea wire is more like a coax cable? wow audio is confusing lol
Old Jul 11, 2006 | 09:22 PM
dodgedlr's Avatar
dodgedlr
That blue antanae wire is only if you have a power antanae that raises and retracts with the ignition switchy.
Just fold it over and tape the end.
Old Jul 11, 2006 | 09:26 PM
habeba86's Avatar
habeba86
That is if you have a power antenea...You do not use that wire. Jst plug the antenea wire into the back of the radio.
Old Jul 12, 2006 | 02:14 PM
neoncrazy101
ok 2 question... with the wiring adapter do i connect the Jensen wiring harness to the wires that are just hanging on the adapter? cause at end of the adapter is the Chrysler ones that plug into the Neons harness and then on the other in where the 2 plugs connect to is a really big gray box thats 2 big for the Jensen.
Also do i need to buy a new sleeve? cause the one that was in the Subaru was the factory one.
