Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2 amps
Old Aug 13, 2006 | 11:18 PM
Newneonguy's Avatar
Newneonguy
Default 2 amps
I looked and could not find what i wanted to know so i will just ask. can i just buy another 8gauge amp kit to run my second amp and have 2 8gauge power wires instead of using the 4gauge and dist. block method? it will be alot cheeper than any other way i have seen. any other ideas or suggestions are great thanks
Old Aug 13, 2006 | 11:35 PM
speakle's Avatar
speakle
Default RE: 2 amps
The right way would be the 4awg with the dist. block but I see no reason other than a sloppy installation.
Old Aug 13, 2006 | 11:45 PM
DieselDemon's Avatar
DieselDemon
Default RE: 2 amps
You need to add up the total amperage that both amps will consume. I would make sure the trucks electrical system has enough to power, and then decide which way you want to go from there. Running 2 individual 8's does not hurt anything. Just make sure both are fused seperately. Also make sure the grounds are equal gauge as the power wire(s).
Good luck.
Old Aug 27, 2006 | 10:25 AM
hockeynut52's Avatar
hockeynut52
Default RE: 2 amps
I am doing my install today. Using 4 Guage from the Battery and from the block 8 guage to the amps. It will make sure you don't overheat the amps and insure they have good current consistently which transalates to better sound. Don't get lazy, do it right. 4 awg , dist. block then 8 guage to the amps. My $.02
