Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
stock head unit with an amp
Old Aug 25, 2006 | 02:49 AM
nash1970's Avatar
nash1970
Default stock head unit with an amp
I want to keep the stock head unit and install an amp with new speakers I just want to know if anyone has done this .
Old Aug 25, 2006 | 03:30 AM
habeba86's Avatar
habeba86
Default RE: stock head unit with an amp
Many have done this. You can get a simple loc unit witch jst uses the signal from your speaker wire. http://www.crutchfieldadvisor.com/IS...ps.html?page=4 You can also jst get an amp with a high level input and you dont have to buy anything. There are also a few that flatten the eq and give you better sound quality. Its up to you and how much you wanna spend.
Old Aug 25, 2006 | 01:40 PM
JLTD's Avatar
JLTD
If you select an amplifier with differential balanced inputs, you don't need to use nasty LOC's to connect the amp directly to the deck. Unless you spend alot of money on them, LOC's typically use transformers that have no business in audio. Here are examples of amplifiers with the proper input section to accomplish this task: Amplifiers
