Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Help with speakers !!!!
Old Sep 2, 2006 | 02:40 PM
nash1970's Avatar
nash1970
Default Help with speakers !!!!
I need to know witch is positive and witch it negative I have to cut the factory connector off so I can install my new speakers .
Old Sep 2, 2006 | 03:09 PM
habeba86's Avatar
habeba86
Default RE: Help with speakers !!!!
If there is a black tracer line on the speaker wire that is more than likely negative. If there isnt a tracer, get a 9 volt battery and hook it up to the speaker. When the speaker pushes out the positive and negative are hooked up rite, so jst remember what wire hooked to what connection on the speaker.
Old Sep 4, 2006 | 02:11 AM
speakle's Avatar
speakle
Get a digital multimeter, set it to dc, turn the radio on (make sure the wires arent touching each other or anything else) and hook up the leads. If you have them wrong the - will show.
