Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
cb radio noise
Old Oct 17, 2006 | 12:07 PM
bud's Avatar
bud
Default cb radio noise
Can anyony tell me how I might get rid of the Alt. whine in my radio. Ive installed a cap at the alt. and add ed ferrit beads to my wireing. Does Dodge have an answer for twoway radio noise ? HELP HELP HELP!
Old Oct 18, 2006 | 05:07 AM
habeba86's Avatar
habeba86
Default RE: cb radio noise
Good ground?
Old Oct 20, 2006 | 10:15 PM
bud's Avatar
bud
All grounds have been checked with an ohm meter. Existing, as well as those I have added.Sure would like to solve the problem.
Old Oct 21, 2006 | 07:16 AM
habeba86's Avatar
habeba86
Is it jst in the cb or do you also have it in your speakers. Im taking it the cb is wired in, not plugged into the cigar lighter?
Old Oct 21, 2006 | 06:26 PM
bud's Avatar
bud
Its just the CB its coming in at the antenna so I need a fix at the alt. I added a radio cap at the battery side but didnt help much.I also have a lot of noise off my injectors but I plan to wrap them in copper tape and ground it. I have already placed ferrit beads over everything.EVERYTHING!!! Cut the antenna loose and I have no noise from anything????
Old Oct 22, 2006 | 06:31 PM
Ram1500Dodge's Avatar
Ram1500Dodge
where do you have the antenna cable running? be sure that the antenna cable is not running alongside of any wires with a power source going through it
Old Oct 22, 2006 | 11:21 PM
bud's Avatar
bud
Power comes off the battery useing the big RG-8 shielded coax grounded at battery and inside at the radio end.Coax from antenna comes from the toolbox mount. They dont travel together.I may be a little picky but I like my mobile to be very quite like my base station.I know its possible as I have had it in the past.You cant here the whine until theres a quiet period on the channel but Id like to cure this.And I will. LOL
