Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
True ignition source?
Old Oct 27, 2006 | 04:18 PM
BeachCrawler's Avatar
BeachCrawler
Default True ignition source?
I have a 1999 Ram 1500 and I need a true ignition source for an isolator. Can anyone point me in the right direction?
Thanks
Old Oct 27, 2006 | 09:26 PM
habeba86's Avatar
habeba86
Default RE: True ignition source?
1999 Dodge Ram Pickup Security Information
Constant 12V+ Pink/Black or Red Ignition Switch Harness
Starter Yellow or Blue/Yellow Ignition Switch Harness, Must Add Relay for Remote Start
Ignition Dark Blue Ignition Switch Harness
Ignition 2 Black/White Ignition Switch Harness
Accessory Black/Orange Ignition Switch Harness (Heat/AC)
Tach Black/Gray PCM Passenger's Rear of Engine on Firewall
Neutral Safety Wire Black/White (-) Ignition Switch Harness
Brake Switch White/Tan Brake Switch or Ignition Switch Harness
Trunk Pin n/a
Parking Lights Black/Yellow (+) Driver's Kick Panel White Connector Driver's Kick Panel
Head Lamp Light Green/Black Steering Column
Factory Disarm Light Green/Orange (-) 24 Pin Connector behind Driver's Dash
Door Trigger Yellow (-) Driver's Kick Panel White Connector Driver's Kick
Door Lock Orange/Purple (REV) 10 Pin Connector Driver's Kick Panel Reverse Polarity
Door Unlock Pink/Purple Driver's Kick Panel
Driver's Lock Orange/Black Left Kick Panel
Driver's Unlock Pink/Black Left Kick Panel
Passenger Unlock Pink/Purple Left Kick Panel
Horn Wire Black/Red (-) 74 Pin Connector behind Driver's Dash
Windows Up LF=Light Blue, RF=Brown/White
Windows Down LF=White, RF=Purple/White
Old Oct 29, 2006 | 12:15 AM
BeachCrawler
Thanks, that should get me started.
