Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Need Part#
Old Nov 26, 2006 | 10:14 PM
ThirdGenNut's Avatar
ThirdGenNut
Default Need Part#
Does anyone have the part number for the Infinity sub in a reg cab SRT Ram.
Pics and info would be great as well.
My 04 has the base infinity package. Will they work together?
Old Nov 27, 2006 | 12:25 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: Need Part#
You'll need the amp that goes with the sub as well. I had both of them laying around a while ago. I got rid of the sub but if you need the amp I think I still got it. Only thing I'm not sure of is if the wiring harness would already be in the truck. If it is there would be 2. One near the rear wall of the cab under the carpet coming from the passenger side. And one under the center console. If both plugs are there it should just plug right in and you should be golden. If not you'll have to run the sub off an aftermarket amp.
Old Nov 27, 2006 | 01:51 PM
ThirdGenNut
Thanks, but I have a small 100 watt Kenwood sub-amp that can run off a speaker level input.
It's supriseing the amp wasn't built into the sub.
Was the sub considered the 7th speaker? I've never seen the sub used(except in the srt).
I count 6 in mine(dash, door and rear pillar).
If anyone else has one to sell, I'm interested.
Old Nov 27, 2006 | 01:57 PM
rtkota5point9
Actually it was the 8th speaker. There is a speaker in the center of the dash as well. And yeah it has a seperate amplifier. I think it's only a 50-75W amp so your 100W should be fine. Good luck in your hunt.
