Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
post install questions
Old Dec 20, 2006 | 11:55 PM
weswing04's Avatar
weswing04
Default RE: post install questions
The Line Out Converter is gone, I have an Alpine head unit now... The hiss is gone completely, but I still get the alternator whine, and only through the amp'd speakers.. so I think it HAS to be the ground. It is currently grounded to the left hand rear seat rail bolt. I sandblasted the bolt so its bare, i sanded the bracket so its bare, and i have a lot of wire wrapped around it. I'm lost.. again.
Old Dec 21, 2006 | 01:01 AM
habeba86's Avatar
habeba86
So you did sand the paint on the floor of the vehicle where it will bolt down to? Are you using a ring terminal or are you jst smashing the wire under the bolt?
Old Dec 21, 2006 | 01:33 AM
weswing04's Avatar
weswing04
It screws into the frame of the truck, I can see the ground through the hole. It was bare.
I didn't have a ring terminal available, so for now the wire is smashed below the washer.
I feel dumb asking all these questions - I've done a bunch of installs and never had a single problem!
Old Dec 21, 2006 | 01:51 AM
habeba86's Avatar
habeba86
Well you should try a ring terminal first....then if it still does it try regrouding it somewhere. Did you run a new ground for the headunit or jst use the one in the wiring harness?
Old Dec 21, 2006 | 01:57 AM
weswing04's Avatar
weswing04
wiring harness..
I read about grounding the head unit, but didn't think that was the problem since the whine is only through the speakers on the amp. if the amp is unplugged, no whine.
I'll try a ring terminal.
Old Dec 21, 2006 | 02:01 AM
rtkota5point9's Avatar
rtkota5point9
Also seat and seatbelt bolts are NOT very good grounds. The reason is they are hardened steel. Hardened steel has less continuity. But getting a ring terminal defiantly will help!
Old Dec 21, 2006 | 02:18 AM
weswing04's Avatar
weswing04
cool, where would you recommend? Drill a hole somewhere?
Old Dec 21, 2006 | 02:46 AM
habeba86's Avatar
habeba86
I would def try re-grounding the amp first. You can search around for bolts and whatnot close and try them and as said b4 make sure all paint is sanded off. If you cant find one close, then yes you can drill a whole and secure it into place. I asked about the headunit, bcuz sometimes if the ground for it is bad it will try to ground through the rca's and give you noise.
Old Dec 22, 2006 | 04:28 AM
HighDuke1911's Avatar
HighDuke1911
the ground for my amp in my truck is under the passenger seat onto the seat. like this rod. it is bolted in there. it works well for me. you should try that if you didnt already.
