stock cross over question
Infinity 7 speaker system, 02 Dodge 1500 QC. Two questitons
1. If I install the Infinity Kappa60.7cs. Do I have to install the cross over that comes with it or does the stock setup good enough where I can just put them on the wires that are there now?
2. How the hell do I get to the front tweenters in the dash?
good choice on speakers.
what your goin to have to do is check the stock cross over to determine if it limits the tweeters the same db as the crossover that came with the speakers does.
i believe that stock infinity takes the tweaters down by -3db or somethin like that.
and good luck with gettin to the tweaters.
anyone can pop in and correct me if i'm wrong.
I have no clue what the frequency roll off points are on the factory set-up....probably 3,000 on the tweeters....I really dont know tho. You can jst wire it up and see how you like it b4 you put everything back together.
