Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Big 3 upgrade?
Old Dec 26, 2006 | 09:38 PM
widowmaker's Avatar
widowmaker
Default Big 3 upgrade?
Anyone done one on a Ram? I've done the upgrade on a few other cars, but I've never seen two wires coming together on a post. What exactly is that, and how can I do the upgrade without messing anything up?
Old Dec 26, 2006 | 10:33 PM
habeba86's Avatar
habeba86
Default RE: Big 3 upgrade?
What do you mean never seen two wires coming to together on a post?
Old Dec 27, 2006 | 03:45 AM
widowmaker's Avatar
widowmaker
It's like one goes to the compter or starter, and then there's the normal battery cable, and they both join together.
Old Dec 27, 2006 | 04:10 AM
habeba86's Avatar
habeba86
With the big 3 all your trying to do is get the mostpower to the amps as you can, so it doesnt really mattery how many times or what the wires split off to from the alt. All you need to do is run power wire from the alt to the batter post and keep the other wiring there. Fuse the wire properly and you will be good to go.
