Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
adding a sub/amp to stock radio HELP
Old Dec 31, 2006 | 05:08 PM
jrebenack's Avatar
jrebenack
Default adding a sub/amp to stock radio HELP
Hey guys.. I recently bought an adapter so that I can continue to use my stock radio unit in mY 06' Dodge RAm 1500 QC. Using this adapter http://www.installer.com/item/display_item.php?it=slocii I will be hooking up an amp for a 10" sub under the back seat... Now the question Ive hooked up amps and subs before, however on the amp dont you need a (remote on or automatic turn on for the amp so that it dosent stay on... Now with the aftermarket decks theres already a specific wire for this...how will i do this with a factory deck.. If anyone knows please help... ThANKS JOnathan
Old Jan 1, 2007 | 01:14 AM
habeba86's Avatar
habeba86
Default RE: adding a sub/amp to stock radio HELP
You can either splice into the ignition wire behind the radio....or go the "easy" route and jst run a wire into the fuse box..to the windshield wiper fuse....you can basically use and switching 12 volt.
For safety purposes I do reccomend throwing small fuse inline between the remote turn on of the amp and whateveryou splice into.
Old Jan 1, 2007 | 01:27 AM
Chopper1's Avatar
Chopper1
I'm not sure which amp you have, but read the manual. One of my amps turns on when it get a signal through the speaker cables.
Or mount one of these under the edge of the dash, seat, etc. I have one in a hidden location for my alarm valet switch and you would have a hard time finding it but can reach sitting in the seat.
http://search.ebay.com/mini-toggle-s...QQfkrZ1QQfnuZ1
http://www.radioshack.com/product/in...ductId=2062516
Old Jan 1, 2007 | 02:35 AM
habeba86's Avatar
habeba86
Ya I think its the mtx amps that have come on when a signal is sent into the high level inputs.
